I am going to be upgrading my fuel system. The feed will be -8AN. I am welding a steel male -8AN fitting to the fuel rail.
For the return I am going to use the original 3/8" feed line. I want to attach a -6AN line to the spot where the stock feed line for the engine attaches at the front frame rail. For those of you that are familiar, the main feed line comes through a small hole in the front frame and the has a rubber hose crimped on with a female Saginaw style oring fitting at the end. I need to find an adapter that will screw into this.
I also need to find the same style Saginaw oring fitting to screw into the bottom of the fuel pressure regulator.
I have one that I bought from Jack Cotton (I believe its an Accel) that was designed to screw into the inlet on the fuel rail, but it is a -8AN and the end that screws into the fuel rail is larger than the regulator threads.
Anyone know where I can get these?
