Looking for an external wastegate
Older Turbonetics Deltagate Mark II P/N 10101. Let me know if any further interest. Can send pictures if you send be email address.
I have a Turbonetics Racegate, 42mm , this is a 2 bolt design not a V band design.
Bryan
Been busy but I'm back on the hunt. Needs to fit as a replacement for this old setup I know not all of them will work with this dp..
That's a old ATR, I have brand new flanges if you need.
I'm guessing the flanges make it adapt to fit any wastegate? How much for the flanges? Are they weld on?
Galaxy S7 Edge
Fyi .. it super easy to mod the Downpipe to make any wastegate work ... did that one fail or are you looking to replace for other reasons ?
It doesn't adjust anymore. I'm guessing the diaphragm inside is toast. Not sure if it's worth the hassle to hunt one down and rebuild it.
Galaxy S7 Edge
Galaxy S7 Edge
I would at least open it up and see what the issue is .. that will tell you how bog of a job your looking at ..
its simple to mod the down pipe for a newer style wastegate if you cant fix the ATR ...
Galaxy S7 Edge
The Turbonetics Evolution or Tial should work fine if you replace
Well I finally got some time to open it up and the diaphragm inside is perfect. I spayed the shaft with wd40 and it moves smooth now. Only problem is the gasket by the diaphragm cracked and I can't find another.
Galaxy S7 Edge
Galaxy S7 Edge
Common on that gate.... I had 1, issues w/ the valve stem/guide.
Considerable talk on other forums about the Chinese knok-off stuff, such as fake Tial, being junk. Most w/ leaks, some sticking, etc.
If you step up, there are several that are good Q. Tial, JGS, PTE, etc.
There's other issues w/ the stem to guide clearance. That WD will last just long enuf to get some elevate egt to it.
If you have it apart, take a close look at the stem/guide.
I have a complete 3.5" GN1 downpipe with the 44mm waste gate. No problems and worked very well with my old 6766cea. It even has some performance modifications I made with a hammer:) $375 plus shipping
Galaxy S7 Edge
If you don't want to deal with it .. let me know .. I will take it off your hands
