i want to get rid of mine, it will easily make the drive to michigan, and i could meet you somewhere. i can get you pics and stuff if you want, very nice body on this one, 2 rust spots, the size of a couple nickels is all. anyway i want it gone soon, heres the details.
BODY
console is cracked on the base, inside the compartment.
needs headliner replaced
cruise doesnt work.
needs shifter handle
135k miles
small dents on trunklid, and one slight wave on passenger quarter(very slight) from a shoe.
very small rust spots on the bottom front corners of the doors
MECHANICAL
motor has NEVER been opened, headers leak somewhere
transmission (original) in need of a rebuild sometime, shifts fine, but getting long under full power.
A/C does not work but complete
turbo exhaust housing has bad bolt hole
MODIFICATIONS AND IMPROVEMENTS
ALL suspension bushings replaced 3500 miles ago, POLYgraphite in the front and poly in the rear.
all new suspension parts
new front tires, 275/50/15 BFG drag radials in the rear
UMI Performance rear control arms
XP fuel pump, ADJ. regulator, 36# bluetops, fuel press guage
Scanmaster 2.1
ALKYcontrol progressive alcohol system
3" single exhaust, cheap homemade 3" downpipe
TE-44 w/precision housing
K&N filter
3000 stall D5 converter
comes with factory turbocharger
I will deliver a fair distance like WI border or something for 6500
PM me and i will give you my number and some pics if iterested.
Gary
