you want ideas?
Here's my setup:
1. I have my PCV valve plumbed up pretty much like stock, with a check valve between the PCV and the intake to ensure no back flow when in boost.
2. I have one of those Fram clear plastic fuel filters, like what you might find on an old carb'ed car, plumbed between my PCV and the check valve. This will trap some amount of oil entrainment (though not a bunch before it gets saturated), mostly it's nice to have to visually see how much oil carryover you are getting.
3. I have open breathers on both valve covers, but I also have check valves between the breathers and the valve covers. Why you might ask? Because:
a. It lets the PCV actually pull a good vacuum on the crankcase. Last time I checked my crankcase at idle was around 6-7" Hg.
b. The low crankcase pressure means it is a lot easier for the PCV to get contaminants (water, fuel, etc) out of the oil - those things evaporate easier under a vacuum.
c. The low crankcase pressure helps eliminate oil leaks. Air trying to get into the crankcase means oil has a hard time seeping out of valve covers, rear mains, etc.
d. When cruising around the low crankcase pressure is helping ring seal. Not sure if this really helps much or not, but directionally it's the right way to go.
e. The low crankcase pressure means the actual flow through the PCV valve is greatly reduced. The closer the crankcase pressure is to the intake manifold pressure, the less flow you get through the PCV. Open breathers give you the highest flow through the PCV. To me this says you are less likely to get oil carryover than with open breathers.
f. Once you get into the boost, any blowby you do get will pass through the check valves and the breathers as normal. You might get a crankcase pressure a hair higher than if the check valves weren't there, but really the ones I used have very little restriction.
Basically, the breather check valves have a lot more advantages than disadvantages, especially on a street car. I got my fresh rebuild going last summer. First few low boost events I saw a bit of smoke out the breathers, but that was gone after the first day or two. Then I got some oil in the clear fuel filter for the next hundred or two miles or so, but once I really started giving it some boost, and the rings got seated good, that stopped. I now see very little oil in that filter.
John
