First off it has the TE housing (like the 51) which flows a little more air than the TA housing on the TA49. I would assume that all three have the Precision .63 A/R exhaust housing. The TE60 has the same turbine wheel as the 49 but has the bigger 60-1 compressor wheel. The PTE51 has the same compressor wheel as the TA49 but has a bigger turbine wheel. Both the 60 and 51 will spool slower than the 49, and both will make more power. If I had to I guess I'd put the 60 as slightly "bigger" than the 51, but they are really close. The PTE52 has about the same turbine wheel as the 51 but has the 60-1 compressor wheel so it is another step bigger than the 51/60, and still spools well with a modified stock torque converter. There are lots of other choices involving the new GT wheels and turbos but the first question you have to answer is what torque converter will you run: stock, modified stock 12" 2800 stall, or 3000 stall 9.5" or 9/11 or? Then look at your driving/useage. Do you want instant spoolup for great 60' times (and tire smoke on the street), or do you want to maybe give up a little et to get a better top end pull and less tire spin on the street?
