Dan SS2471
- Dec 12, 2008
Here is the car's current setup:
Engine/Exhaust:
-rebuilt about 3k miles ago
-204/214 cam - flat tappet
-ported stock heads
-steel center main caps
-double roller timing set
-020 forged JE pistons
-60# mototron injectors
-hotwired Walbro
-3" LT-1 MAF with translator
-TurboTweak chip
-160* t-stat with billet neck
-Caspers cam sensor cap
-3" ATR downpipe
-Turbonetics Evolution wastegate with in-car adjustability
-test pipe with cutout
-Hooker 2.5" catback
-Rebuilt G-80 rear
Stock turbo set @ #18s max right now, stock trans and converter.
Can't make any baseline passes because the trans needs to be rebuilt. Or I should say it's flaring up at WOT and when it warms up it hesitates to shift on th 2-3 and whines a bit.
First question..based on cars with comparible mods, let's say running at Atco or Englishtown, what would be a good guesstimate as to what it will turn in good air on street tires. Then perhaps throw on some 555Rs or MT ET Streets.
As far going forward, am I assuming if I go bigger turbo, that the way it's currently configured, that it's got sufficient fuel...? If I were aiming for high 10s, what size turbo would be the right fit. Also, since the trans needs to come out for a rebuild, what would be the recommended converter based on bigger turbo? Final question is...based on the re-build specs, how much boost would be considered to still be 'safe' assuming the engine is tuned correctly.
Thanks in advance and I hope I'm not asking too many questions. I have done a lot of reading but am having a hard time putting 2+2 together with this exact combo.
Dan
Engine/Exhaust:
-ported stock heads
-hotwired Walbro
-TurboTweak chip
-3" ATR downpipe
-Rebuilt G-80 rear
Dan
