Looking to buy ALKY
progress1vebmx
Asian man #1
Posted this in the GD forum - here is what I have, do you guys suggest ALKY?
I have a 2.5" Turbonetics DP, which I am replacing with a TH DP. Definitely getting new tires for 140$. I am also getting the vacuum brake conversion and Scanmaster for sure. I don't know if I should go with the 3.5" MAF + MAFT+ though, or hte ALKY. Here is what I currently have on my car... I'll have rougly 500-600 left after I buy all the stuff I really need.
I am going into the Air Force June 29th, and that's when I'll be putting in 4-5k into my car. Right now I am just working up and building up my car to get ready for the new turbo and all that jazz.
Duttweiler ported big-valve iron heads
GM Head Gaskets
.030 over TRW Forged pistons
Erson LC-11 Cam (202/202)
Polished rods,ARP bolts, Cryo Treated
Crank Cryo Treated, index ground
Billet center main caps
Rotating Assembly Balanced
Block Line- bored
Melling HD oil pump
Block decked
One-Piece main and front cover seals
Front cover oil passages ported
42.5# injectors
Hotwired Walbro 340 pump
Be Cool Aluminum Radiator
Dual Flex-a lite fans
200R4 built/upgraded by JW Performance
Art Carr 9" 3200 stall TC
Stage 4 Turbonetics "Cheetah" (same as 61 series turbo)
Deltagate
Duttweiler Front-mount intercooler
ATR 3" Single Shot
Turbonetics 2.5" Downpipe
Big Mouth Cold Air
Test Pipe
Hooker Headers
The MAFT will allow for tuning what you have, but wont allow the boost level increase alky will.
I say get both :D
If your car has a questionable MAF, dont put an alky kit and increase the boost. Your motor/electronics have to be in proper working order for higher boost to be run. Whether alky or race gas.
Tho I would say get an alky kit before an IC upgrade. But the MAF is the heart of your fuel management system. And I would rather have a nice driving car without alky, then a poorly running car with alky.
HTH
