I actually have achieved your goals but it is not cheap. Read my signature and be prepared to open your wallet to the tune of $6000 in parts. Slapping a few parts on will never get you into the twelves. You have to open up the entire engine from intake through exhaust. Speed is like drugs-you always want more. My only point is you might be better off spending your money on an 86/87 which has alot more potential than a Hot Air. Think before you ever spend. My 2 cents. Brad
Not exactly..... Here's what it took me to get into the 12's consistantly. Consistanly is the operative word here cause it can be done in pure stock trim with "expert" tuning and race fuel.
Stock block and cam
Passenger side header (used) 200.00
Bigger turbo TA33 850.00
2 1/2 Downpipe 140.00
42lb injectors (used) 200.00
Custom chip 75.00
Upgraded fuel pump & Hot wire kit 139.00
Sticky tires 350.00
Total= 1954.00 This supplying my own labor.
With a good 60ft 1.80 or better 101 mph will get you into the 12's all day.
104 mph will get you there with a 2.0 60ft or better.
Now to consistanly run mid to low 12's to high 11's still in hot air trim.
Add a larger turbo, the bigger the better, probably something custom. 800.00
50lb injectors or larger (used) 250.00
Bigger cam (not needed but makes it easier) 125.00
New lifters for cam 60.00
DIY alky kit 200.00 or less
Ported heads 850.00-900.00
Razors alky kit 450.00
Another custom chip 75.00
Custom converter 500.00
Total 5054.00
Sell your used stuff
Ta33 650.00
42lb injectors and matching chip 200.00
Total 850.00
5054.00-850.00= 4204.00
Might throw in 500.00 for a couple of odds and ends.
