Loose Wires
Chatmanboy
This wires are on the Driver Fender wall what do they connect to?
Single wire connector is for the underhood light.
The other one is NOT used. Not sure what the intention of that waire was.
The lighter color plug single wire...
I believe should go to your brake proportioning valve down on the frame kinda right below the power booster. If that is disconnected I would expect your BRAKE dash light to be illuminated because it thinks there is a problem with your brake system. I checked my car this afternoon and my proportioning valve had a plug like that, but not sure if the one pictured is for the brake valve or not.
Good luck,
Jerry jr
if the wire is unhooked from the prop valve, the light will not come on. the prop valve grounds the circuit when the piston inside moves in either direction due to a loss of pressure in either the front or rear brake system.
i think (but am not sure) that the big multiwire plug has something to do with cruise control. my car has that same plug just lying there, and i don't have cruise.
The black and the brown connectors stay un plugged.The yellow one needs to be connected.
