The combo is in the sig. I put on the Powerplate about 2 weeks ago and the IC a few nights ago.
I went for a ride today to check out everything. The car pulls hard and holds ~19psi of boost in 1st and 2nd, shifts into 3rd and drops down to ~12-13psi then starts creeping back up the 18-19psi over about 4-5 seconds. This has never happened. What the heck is happening?
When I put on the plate, the passenger side rear bolt started to turn a bit on me, but it's not stripped and is snug. I double checked all the IC hoses.
Is this maybe a problem with the wastegate solenoid? What should I check?
S.
S.
