lost door and trunk keys
riviera
I lost the trunk and door lock key is there a easy way for a locksmith to remake this key or is it cheaper to replace locks
If your car is locked take a coat hanger and open the door . Hopefully your car has a power trunk then pop the trunk and remove the trunk lock and bring it to the lock smith. If no power trunk then take out the back seat and take a few real long extensions and unbolt the latch from trunklid
take the glove box lock into a locksmith...
assuming, of course, that the glovebox lock still used the same key as the doors and trunk..
I called the lock smith and he came to the house and cut new keys for the car for $60.00.
I took the lock cylinder to the lock smith new keys in a couple minutes. Cheap!! Did I tell you about the time I locked my keys in the trunk and my tool box was in there too!
I locked my keys in the ignition 3 times in the last 2 weeks... my jimmy bag was in the trunk all 3 times:oops: . Finally getting use of 10 years of AAA membership. Same driver on two of the calls, we had a good laugh.. probably at my expense.
depends on where you lost the keys ( i am paranoid)
lost the keys in an area around or near the car -- get a new lock set including Ignition switch- BTW i do this to every car i buy from a local seller (dealer or private).
lost them down a sewer or some place where they will never show up by your car again, or in your house then make another set of keys for the same old locks. otherwise see above^^
