Just bolted on a rebuilt carb recently. The settings were way off (TPS and mixture control). Finally I adjusted the tps to 1.20v and the mixture control i moved 3/4 turn clockwise. I was seeing up into the high 600's on the otc 2000 at part throttle. Car seemed to be running good until i gave it some boost 5-10. Then it started stumbling really bad. I had to keep pating the gas to keep it from stalling all the way home. checked one of the plugs thinking they were fouled the tip was alittle white but it seemed to be smutty around edges. I know that i was hearing some light spark knock too. Seems to be bogging if i rev the motor. could this be weak ignition? Can someone tell me whats wrong?
