lots of buick parts for sale
outlaw7d9
87 gn spindles powdercoated bl;ack modified for styrange barkes come with the aluminum caliper brackets on them. 100.00
aluminum buick v-6 front motor plate 50.00
magnecore 10 mm wires good condition all ohm within 5 ohms per foot make offer
new vac block for above the throttle body has vacuum port for power brakes only 25.00
brand new alternator power coated silver only run on aklternator test machine 2 make sure works properly after podercoating 150.00
lower race pullet underdriven brand new not sure of manufacturer 45.00
used front timing cover does not include water pump shown in pic 30.00
brand new precision turbo .81 exhaust housing 4 bolt fklange 100.00
stainless thermostat housing with hold down and new 160 t stat 20.00
auto meter 5 inch tach works fine 20.00
aluminum core support 300.00
fiberglass glasstek doors perfecr condition with power window motors tracks and latch assemblies 500.00
kenne bell front ram air air dam nice shape in primer no cracks or repairs 40.00
gm maf sensor works perfect out of an 87 45.00
engine sensors egr control solenoid boost control solenoid tpa knock 40.00 for all
perfect condition complete cam sensor35.00
87 gn headlight switch 10.00
what brand t stat shipping to 90605 CA THANKS.
AL
Do the doors bolt on to the factory hinges, or are they pin on?
Thanks-
Danny
they bolt 2 the factory hinges once on the car its hard 2 tell there fiberglass they use the stock fdoorpanels and everything including the handles and lock on the outside they even have the bolt holes for the mirrors
Glass doors
Can you post a pic of doors? Are you shipping these or are they pick up only?
2nd in line for t-stat housing.
Conrad
