278cikiller
- Dec 21, 2007
Very nice 87 Crome Grille From a N/A Car no chips or cracks $80.00
head light & Dimmer switch $50.00
speed-do in lay $40.00
3 Vaccum brake systems with pedal no vaccum block $100.00 each
thrid brake light no mounting bracket $30.00
GNX Lazer cut Turbo cover this has to be tack weild on the side see pic.$200.00
crome and black vavle breathers $25.00 each
stock in let bell $40.00
y bracket $40.00
stock tube for passenger side vavle cover $25.00
G/N shifter handle nice shape $40.00
stock headers with cross over pipe with two delta gates atach this headers will support well over 700 HP with no issues and no leaks $275.00 and these sound unbelievable when they open up at ten pounds of boost.
3"to 4" adapter for stock headers for a four bolt turbo $50.00
exch. .83 housing with stock elbo this housing came off a TE-44 turbo $50.00
Pair of 3" tail pipes wit hangers $150.00
Coil pack and mouduel with backing plate $150.00
109 block done 30 over with one sleve in #6 cylinder all the machine work was done with new cam bearings The block is still in the plastic bag,comes with 6- 30 over pistons and stock rod,stock timing chain cover.fly wheel,arp studs for stock heads,pair of stock vavle covers,harmonic balancer and pully wheel,delet pully,water pump and pully and all the nuts and bolts and hardware. This block does not have crank,oil pick up and pan. What you see in the pics is what you will resieve no B/S.
The Pistons are worth more than this deal alone.
$500.00 for this package on the block and parts that go with it. I will build the crate for free and ship it TNT Or Overland exprees Trucking.You pay the shipping
All other parts are plus the ride or phone me at 1-905-419-0704 Dan Thanks!
y bracket $40.00
