Art Carr old school killer 9" N/L converter #16940 with just a few thousand mile's in great condition $350
Bosch 65lb injector's low Z's with only 1200 break in miles, run perfect, look new and awsome with chrome bodys $285
1 Pair of new breather's for Motorsport valve cover's, comes with bypass plug,and good used pass.side grommet $45
1 New GM fender emblem (GN) $35
1 New GM fender emblem (intercooled) $19
brand new set of Comp cam hydr.roller lifters,#853's $295
brand new GM cam sensors $140
1 slightly used GM cam sensor with a couple hundred miles and new o'ring
sensor like new $110
2 used gm cam sensors $50 each
cam sensor adjusting tool, $30
brand new GM egr solenoid controller $35
brand new GM S-shaped bypass heater hose $15
brand new GM coolant & washer tanks $35 for pair
brand new GM oil o'ring for filter housing $8
1 new GM center cap for 86-87 gn, $18
2 new 3" H.D intercooler blue hoses with H.D clamps $25
1 set of H.P push rods, a couple of hunderd miles on them, 8.700 $18
1 87 non turbo crank with rods, at standard, not damaged, make offer!!
42lb green stripe injectors $135
precision adapter for oil filter relocator, screw on adapter and h.d fittings $25
Stock turbo exhaust elbow, blasted & painted $35
34mm front sway bar from Trans Am $45
vdo elect. temp and volt gauge,black face $15 each
1 86-87 GN rim,center cap and dunlop gt 235-60-15 tire with 75% tread,rim has a little curb rash $85
Used GM ignition module & coil $85
E-mail me direct at Turbogta@aol.com
