Most of the parts listed here are from some of my low mile cars that I have owned over the years. Many parts were removed way back in 1987 - 1990 Many parts are in excellent condition, many look brand new.
Keep in mind that many of these pieces are intended for those wanting to put their car back to stock with OEM show quality pieces. That was the purpose of me keeping / acquiring many of these pieces. But now that my last GN has been sold, the items are no longer needed.
Several parts can be seen at www.hbscomputers.com/parts2
Fuel rail end cap. $2.00
3.8 SFI hood badge $5.00
Lower control arm hardware $5.00
Stock shifter cable $15.00
Transmission cable brackets (trans side) $10.00
Front Sway bar hardware with bushings $15.00
Stock fuel pressure regulator $10.00
Stock intercooler hoses and clamps 3 hoses and 6 black clamps these are show quality $50.00
Stock oil fill cap $6.00
Stock Seat belt guides $2.00
Stock gas cap $1.00
Center console shifter plate $30.00
Stock ECM computer chip $20.00
Stock ECM $50.00
Stock plastic seat mount slider trim (black) $10.00 for a set per seat
Fuel line heat shield (located above gas tank) $2.00
Stock shifter mechanism $50.00
Stock shifter handle complete $35.00
Stock muffler hangers above rear axle $10.00
Stock oil cooler lines (both) $50.00
Stock oil cooler adapter $20.00
Catalytic converter hanger $10.00
Stock Plenum $30.00
Stock Throttle body w/o linkage $40.00
Intercooler fan $45.00
Down pipe gasket $1.00
Stock flywheel $25.00
3 Fuel line set from sending unit to cars main fuel line $6.00
Stock up pipe $20.00
Stock serpentine belt $5.00
Jack and tire Iron (never touched the ground) $40.00
Rear lower control arms (pair) $40.00
Charcoal canister $30.00
Crossover pipe $30.00
Stock intercooler $110.00
Stock intercooler shroud Super nice looks brand new with screen $95.00
Stock MAF Hose $5.00
Mint Stock air box with bolt, elbow and inlet snorkel this is show quality $60.00
Rear view mirror $10.00
Ash tray $5.00
Rubber fuel line hoses (3) from sender to fuel lines above gas tank $6.00
Cigarette Lighter $5.00
Clip for oil cooler lines $2.00
Stock OEM radiator hose clamps $4.00
Alternator bolt $5.00
Door handle pull strap screw covers (2) $12.00 for the pair
Grill badge (BUICK) $2.00
Cruise control cable hardware $2.00
Pinion snubber $2.00
Gray valve stem caps $1.00 each
MAF Bracket and bolt $2.00
Air Dam bolts $2.00
Original rubber vacuum lines from metal vac lines to TB vac block $5.00 for all
Breather and tube to turbo Mint show quality $15.00
L & R Valve covers $45.00 each
Door lock pull up (OEM chrome ones) $2.00 each
OEM Catalytic converter clamp $5.00
Water temp sender $2.00
GN Center console with shifter plate (from 1000 mile car) $250.00
Interior carpet from 500 mile car $450.00
Stock D5 Torque converter $75.00
Plastic vacuum ball Mint condition $10.00
TV Cable $25.00
Other very nice GN related parts
1 Nice Genuine GN header panel with head lights $400.00
2 Aluminum brake drums Virtually brand new, less than 1000 miles on them $125.00 each
Hood latch cable release $15.00
Cruise control cable $20.00
Pair of brake lines from Master cylinder to proportioning valve $35.00 pair
Hood latch bracket $5.00
Rear view mirror $15.00
L & R Door mirrors $20.00 each
Set of A/C Lines with support clips $90.00
1 Gutted cat converter $20.00
1 good low mile Cat converter approx 12,xxx miles $50.00
1 set Upper and lower rear control arms $60.00
Super nice rear GN Spoiler (all 5 pieces) $250.00
Set of original GN wheels with Good Eagle GT +4 tires been stored the past 13 years or so $800.00
Super nice no rust radiator support $100.00
Cowl trim black $25.00
Mint set of GN Seats removed from GN with less than 1000 miles on them both with manual tracks $850.00
Mint set of GN Seats removed from GN with less than 500 miles back in 1987 with power track $850
Super nice Mint OEM gray trunk carpet kit removed back in 1987 from a buddy’s car with less than 500 miles on it. Stored in plastic all these years $200.00
1 Nice GN trunk ldeck id (no spoiler) $175.00
2 Rear window glass with defogger $50.00
Front windshield $70.00
Front sway bar $15.00
Very nice complete front and rear bumper with bumperettes, rub strip and bumper support
$300.00 front with lights & bezels, bumperettes, rub strip and bumper support. $250.00 rear with bumperettes, rub strip and bumper support
L & R Front fenders $40.00 each
L & R Front fender supports $15.00 each
L & R Front plastic fender liners $100 for pass side $50.00 for drivers side
Front and rear aluminum bumper supports $100.00 each
Pair of rear tail light lenses with black trim (from 1000 mile car) $350 for the pair
Stock turbo cover $25.00
Chromed stock turbo cover $75.00
Pair stock rocker arms $30.00 pair
6 stock pistons and rods $120.00
stock push rods $2.00 each
Oil pickup $5.00
Fuel lines from gas tank to front of car (they are like 10 feet long) $100.00 for all 3 WILL NOT SHIP
3 spare tires $10.00 each
1 Spare tire never touched the ground $50.00
L & R rear qtr windows $75.00 each
Super nice tilt steering column with keys $175.00
Nice black window trim pieces for front and rear windows $50 per set of 3
TV cable $25.00
PLEASE EMAIL ME DIRECTLY IF INTERESTED, NO PM's PLEASE
email is joe@hbscomputers.com or you can call me at 630-707-0200
SHIPPING IS FREE IT IS ADDITIONAL
Many large items are for pickup only in the Chicago West suburbs or I can deliver to the GS Nationals in May for you.
Please, if I don't respond, please do not feel offended. It just means that I don't have the part or the part has been sold.
Thank you
Joe Harrington
Stock gas cap $1.00
Stock ECM $50.00
Stock Plenum $30.00
Ash tray $5.00
Air Dam bolts $2.00
TV Cable $25.00
Oil pickup $5.00
TV cable $25.00
Thank you
Joe Harrington
