87 WE2
- Jun 28, 2002
Lots of parts for sale: exterior, interior, engine, trans, suspension.
Exterior:
Rear bumper impact strip (all black) 8 out of 10 very nice. $75
GN black rear bumperette, great cond. $20
GN black rear bumperette, stud cut, black impact pad good $Make Offer
GN rear bumper with rust in inside, paint bubbles front rust on outside $Make Offer (pick up only).
Rear bumper support, steel $ make offer (pick up only)
Front bumper support, steel $ make offer (pick up only)
Stock fuel door/license plate holder $5
Trunk latch, with hardware $Make Offer
(2) GN emblems used, $10 each
Antenna guide and nut for fender $5
Quarter panel vents $15
License plate nylon nuts $5
Under hood light used $Make Offer
Interior:
Door escution trim, chrome missing on end near pull strap $15
Gray seat belt trim $Make Offer
Cruise control, black control box for under dash $10 (2 each)
3rd brake light (gray) housing good, light guts broken, UD LOOSE screen in housing $Make Offer
Passenger side window switch $5
Vss buffer, inferred eye missing $20
Door lock pull up knob $Make Offer
NOS Brake switch $20
Used IGN switch $5
Gray B pillar trim (pair) $15
Engine:
Turbo shield cut for 3” downpipe, new triple chrome plating $150
Exhaust elbow, mildly ported $55
Mint triple chrome plated oil fill tube with cap $90
Complete cam sensor, used working cond $75
2” heavy duty intercooler to turbo couplink & T clamp $10
Heater relay $10
Pass side valve cover spark plug wire holder $5
2.5” exhaust clamp $Make Offer
2.25” exhaust band clamp brand new $Make Offer
2.5” testpipe $Make Offer
Stock flex tuber MAF to TURBO $25
AC line flex tubing $5
Starter heat shield $15
Good 2 bar map sensor $30
3” cutout pipe block off plate with wing nuts and tool $15
Trans cooler line, short rad side $5
NOS EGR valve solenoid $65
EGR valve good used $10
Stock vacuum pod with gasket & bolts $45
IAC gasket $5
Stock oil filter adapter nut $5
T-Stat housing $10
Good used crank sensor with mount $25
Stock stat new $5
Good knock sensor $10
Delco 02 sensor used good low miles $20
Used oil pump pickup $5
Suspension:
2 steel brake drums, painted with silver vht 1500 deg paint $Make Offer
Stock rear swaybar with hardware $40
Stock lower control arms, $50
Trans parts:
Misc trans pan bolts $5
Good used D5 converter $75 pick up only
2 torque converter inspection cover (one missing a bolt tab, other has cooling holes drilled) $Make Offer
19k mile trans pan with bolts $30
CK performance custom street/strip valve body kit new $350 must send your core valvebody to ck (more info on his site)
+ shipping on all parts to 48 states, unless pick only is noted
See pics of most parts turbo231/Parts for sale - Photobucket - Video and Image Hosting
If there are no pics of certain parts listed just ask.
Thanks, Ed
Exterior:
Interior:
Used IGN switch $5
Engine:
Heater relay $10
IAC gasket $5
T-Stat housing $10
Stock stat new $5
Suspension:
Trans parts:
Thanks, Ed
