Squid4life
- Jul 5, 2004
Need to get rid of a bunch of parts taking up too much space in the garage, plus need money to fund other things. Prices are not shipped unless otherwise marked. I have included the weight and size of box or envelope so you can check shipping if you want to, otherwise I will as soon as I can. I am in 91913 zip code. I am in some training this week for work, so not near a computer during the day until about 5 pm. Prefer to ship USPS except big/heavy items which usually go to the UPS store. I do have paypal, and prefer that method of payment. Let me know if you have any questions.
Pics are here: http://s35.photobucket.com/albums/d190/Squid4life/STUFF FOR SALE/
ATR STAINLESS EXHAUST WITH PITBULL MUFFLER, MINUS TAIL PIPE. $200
22LBS 7 OZ 48X12X9 SOLD
EDELBROCK 204/214 CAM, BRAND NEW WITH LIFTERS. TAKEN OUT OF BOX IN PREP OF INSTALL BUT NEVER ENDED UP USING IT. I HAVE THIS EXACT CAM IN MY CAR AND LOVE IT. NO ISSUES WHATSOEVER. $100
10 LBS 3 OZ 18X4X4 SOLD
STAGE RIGHT TRANS BRAKE, WITH DETENT PLATE, VALVE BODY GASKETS, INSTRUCTIONS, ETC. ALL NEW. $130
13 OZ 10X6.5X2.5 SOLD
CASPERS AUDIBLE KNOCK ALARM $20
7 OZ 7X5X3 SOLD
BLAZER FRONT BRAKE ROTORS, COULD USE A TURN AND SPRAY JOB. STILL LOTS OF MEAT. WILL THROW IN DECENT USED PADS IF YOU WANT THEM. $15
LARGE FLAT RATE BOX
LS COIL NEAR PLUG WIRES FOR LS COILS (6 WIRES) (OR BOB BAILEY V6 SET UP) INSTALLED AND TESTED A FEW TIMES, I GOT WITH PURCHASE OF A CAR AND I HATE RED… MSD 8.5 SUPER CONDUCTOR, WITH LITTLE CLIP ON #’S. 12” LONG EACH FOR CNP WHERE COILS ARE ON VALVE COVERS. $35
1 LB 10X4X2 SOLD
VDO PYRO GAUGE AND SENDER $45
15 OZ 7X4X3
CASPERS HIGH/LOW FAN SWITCH, BRAND NEW WITH INSTRUCTIONS. $25
5 OZ 10X4X1.5 ENV SOLD
RJC POWER PLATE STOCK PLENUM. $35
5 OZ ENV SOLD
RJC QUICK SPOOL VALVE/ BOOST CONTROLLER. $35
5 OZ 7.5X2.5X2.5 SOLD
RJC PCV CHECK VALVE $20
3.2OZ ENV
MOOG 5413 REAR SPRINGS (LOWER ~1”, LOOKS KILLER) ABOUT 5K ON THEM. $40
17LBS 18X17X8.5 SOLD
OIL PUMP MISC: TA PERF OIL PRESSURE REGULATOR, STOCK AND HV GEAR SETS, WEAR PLATE, SPACER, MISC SPRINGS FOR DIFF PRESSURES, BYPASS VALVE, BOLTS, FRONT COVER SEALS (NEW AND OLD STYLE, FUEL PUMP PLATE GASKETS, PICK UP TUBE GASKET, ETC, ETC $30
SMALL FLAT RATE
B4B DISTRIBUTOR $50 (PAID $50 FOR IT AT THE SALVAGE, PICKING IT UP FOR SOMEONE ELSE WHO WENT MIA. JUST WANT TO MAKE MY $ BACK)
7LBS 13X11X9 SOLD
B4B QUADRAJET CARB $45 (SAME AS ABOVE, JUST WANT MY MONEY BACK PAID $50, SELL FOR $45?)
LARGE FLAT RATE SOLD
PIONEER 5 ¼” DOOR SPEAKERS, NEW IN BOX. 130 WATT $20
3LBS 14X9X4 SOLD
FULL SET OF 6 (PLUS 4 SPARE) COPPER HEADER GASKETS. BEST ONES OUT THERE, USUALLY $50+ A SET. $25
11OZ 7X4.5X2.5 SOLD
PAIR OF OUTER TIE ROD ENDS (NEW IN BOX, AUTOTECH MADE IN CANADA) $17
2LBS 7 OZ 9.5X3.5X2.5
BENDIX REAR BRAKE HOSE NEW IN BOX (HAVE 9 OF THEM) $7 each
5 OZ 8X4X1
SET OF ALL 3 BRAKE HOSES NEW IN BOX (2 FRONT, 1 REAR) set 1 $28
14 OZ ENV
SET OF ALL 3 BRAKE HOSES NEW IN BOX (2 FRONT, 1 REAR) set 2 $28
15OZ 9.5X3.5X2.5
PAIR NEW REAR WHEEL CYLINDERS pair 1 $14
2 LBS 3 OZ, 6X4.5X4
PAIR NEW REAR WHEEL CYLINDERS pair 2 $14
SMALL FLAT RATE
RAYBESTOS PREMIUM FRONT BRAKE PADS, NEW IN BOX. $14
SMALL FLAT RATE MAYBE, IF I TAKE OUT OF PACKAGING
GOODYEAR LOWER RADIATOR HOSES NEW $12 (I HAVE 7)
I GUESS I CAN BEND IN HALF AND PUT IN A PADDED ENVELOPE?
2004 FORD EXCURSION FRONT AND REAR DURALAST GOLD BRAKE PADS, NEW IN BOX. PN DG757 (REAR) AND DG824 (FRONT) $30
MEDIUM FLAT RATE BOX
LARGE FLAT RATE BOX
15 OZ 7X4X3
3.2OZ ENV
SMALL FLAT RATE
