Lots of STUFF for sale (NEW & Used) - Local Pick-Up only
Hey, I can't send an email right now (work filter) but how much for the body bushings?
List of parts with prices
NEW PARTS
MAC Mufflers (2) NEW $130.00
Oil/Water Gauges 2in NEW $25.00
Boost Gauge 2in NEW $25.00
(2) Trans Temp 2in NEW $15.00
9in CPE 3500 Stall Torque Converter NEW $600.00
12in 4L60E/30 spline 700 Torque Converter $130.00
CPP Spec 2 Cam NEW $125.00
High Volume Front Timing Cover NEW $150.00
Oil Pump Housing NEW $25.00
Champion Valve Covers NEW $115.00
21/2 x 3 in Hose Coupler NEW $20.00
(3) Turbo Oil Feed Line NEW $15.00
Timing Chain (Double Roller) NEW $50.00
Chrome Inlet pipe NEW $65.00
A/C Block Off Plate NEW $10.00
ARP Head Bolts / Champion Heads NEW $100.00
(4) T/A Single Pillar Mount 2in NEW $10.00
(3) 160 Thermostat NEW $5.00
(2) Fuel Filter NEW $5.00
(2) Huges Trans Brake for Turbo 400 NEW $15.00
Turbo 400 Gasket w/Filter NEW $5.00
Stock Roller Cam Button NEW $5.00
Stock Turbo Dounut Gasket NEW $5.00
Vacume Pump (for vacume brakes) NEW $50.00
Chevy Intake (fuel injection) NEW $500.00
LS1 - SLP 2 1/2 Exhaust NEW $150.00
LS1 - SLP Loud mouth System NEW $375.00
LS1 - Kooks 3in "Y" pipew/Cats NEW $575.00
GOOD USED PARTS
86/87 Accessory Bracket $65.00
86/87 Tensioner $65.00
86/87 Oil Dip Stick w/Tube $20.00
86/87 Trans Dip Stick w/Tube $10.00
86/87 Intercooler Bracket Dr Side $15.00
86/87 Intercooler Bracket Pass Side $15.00
86/87 Turbo Shield Bracket $25.00
86/87 Fuel rail with Harnes & Injectors $20.00
86/87 Fuel Return Line $10.00
86/87 Stock Air Cleaner Box $10.00
86/87 Oil Return Line w/Block Fitting $10.00
86/87 Used Caspers Injector Harness $50.00
Stage II Heads w/Jessell Roller Rockers $1,700.00
86/87 Stock Turbo Elbow $10.00
A lot of Misc ARP Bolts (over 100 misc pieces) $50.00
Used Turbos with leaking seals TE 49/TE60? $150.00
Good Used Starter $15.00
Stock Rear Springs $15.00
Stock Crossover Pipe $25.00
Plenum Spacer $25.00
V/C Spacer $35.00
HD Hose Clamps $20.00
Chrome EGR Cover $5.00
Pinion Snubber $5.00
DP Gasket $10.00
Racegate Gasket $3.00
Front Bumper BLK out $10.00
FRESH Power Glide w/Trans Break $1,375.00
Buick manuals ( a lot of different years 67-92) Make Offer
Interested in these and I am in houston betweem 45 and 249
Im in Humble by Bush Airport. The Fuel rail may be sold. Should hear back today on that. I got your name on the rest of the stuff. I'll PM you when I find out about the fuel rail.
Thx,
Chris
You want $150 for 2 used turbos that need rebuild?
Tell me I'm dreaming?
Oh, and I am interested in the turbo oil lines as well.
Looking at pics now.
and the console lid
and the turbo drain line
And I gotta have the speed limit sign....
and the console lid
Thats $150 each ..... And after further digging, I'm pretty sure its smaller then a TA-60 Make offer for both. The more you buy, The better the deal :)
O.K. guys, I've gotten a lot of "I want this" but no further follow up after I email or PM you. If you interested PLEASE email me at BAGN231@yahoo.com. PLEASE make the subject title the "part" or "parts" you want.
Thank you,
Chris
