It's been almost a year since I've had the car, and I figured I better finally look into my crappy brakes. Car has a vacuum conversion, and the brakes don't seem to grab well at all, the pedal is very hard, and sometimes I have to pretty much stand on them to get the car to slow down. Locking them up is completely impossible.
Also, they seem to be sticking/binding alot. I'll get home and I can smell the front brakes due to constant friction. I notice that when I sit at a light or anywhere when I'm stopped for a minute, that the pedal seems to sink in some and stays there. I let off of the brake and the car won't move, the brakes are still applied and the brake light stays on. After about 7 or 8 seconds the brake will release itself. A few times I've actually had to put my foot under the pedal and pull it back up
The brakes are Teed into the PCV valve which I know needs fixed, and the fluid seems dirty, like there are small chunks of.... something floating in it. Seems kind of watery too. Any good links on how to bleed the master cylinder or flush out the whole system and start fresh??
EDIT: Car has newer rotors, calipers,pads, drums and rear shoes on it.
Thanks in advance.
I've had with these brakes and need to sort it out before I drive into the back of a garbage truck
Thanks in advance.
