Been working on get my TTA to run on newly installed Razor Kit. Before the install i had to run race gas to keep my car from registering knock. Even on 91 with TT chip tuned for the 91. For the most part the car runs fine other than the knock registering and low blms (110 at idle).
Since the kit install, the car does not register any knock (except for slight transitional which goes away) on the same setup. The only thing is, the low blms.
Currently i'm pretty much running a stock setup (stock boost, turbo, 91 octane chip, new 30lb injectors, test pipe with 3"Magnaflow catback, adjustable FPR). Before turning up the boost i'm wondering if i should try and figure out the low blm issue.
The car is runing ok at stock boost levels.
I've searched and there is a lot of info on high blms, but little on low. I understand that low means its running rich but not sure what would cause that. I've tried decreasing the fuel pressure but it does not bring it up.
