I've got a friend's 1987 GN and we are having trouble figuring out what is wrong with it. The car used to be very fast and now its pretty much a terd. The car has like 12k original miles. roughly 1k miles on the new turbo.
The car is very slow to build boost and only builds to about 10psi. We pulled the turbo off and had it looked at by a very reputable turbo shop in town and the guy said there is absolutely nothing wrong with the turbo.
So, I'm trying to diagnose what could be causing this. The engine has a nasty rattle on the passenger side. When the engine is cold you can't hear it, then when its hot the rattle is very noticable. the rattle is not coming from the valve train or the inside of the motor. It sounds like a noisy heat shield but i could be wrong. I would love for it to be a cracked manifold because that would cause the boost issues but I don't hear the typical cracked manifold exhaust leak sounds.
I asked my friend if he could make a connection between the onset of the rattle and the decline in performance and he said no. However, this car has rarely been driven in the past few years.
Any insight would be very helpful. I just wonder if I should chase down this rattle or if it is typical of GN's and not a major issue?
