Lower intake gasket
Loswages05
What lower intake gasket is better the fel pro or the steel one. Just seen mine is leaking oil
The thicker Fel-Pro is more forgiving to pitted and/or warped surfaces. If you're heads have been milled or the block decked, you might have to run the thinner steel unit (or mill the intake if that's the case)
Stock heads and intake
