I heard you need 16" with the F-body brake (12") and 17" with the C5 brake. The hub assembly would allow you to run the Brakes off of an S-10, which I have seen squeezed into a 15" wheel.
You need a hub, spindle, & caliper (dual piston) assembly from a '98-'05 S-10 Blazer 2wd for the 15" wheels to fit. This is a bolt on piece. Downside: 11" rotor instead of 12", sealed wheel bearing, expensive part.
