SignUp Now!Originally posted by UNGN
The LS1 MAF is 3.5" and the LT1 MAF usually refers to the Non-Fbody LT1 MAF which is a 3" version. The 3" LT1 sensor is easily incorporated into the stock hose sizes and still flows more than a stock MAF. The LS1 sensor flows about 200 CFM more than 3", but needs adapters to work (not really a big deal).
Originally posted by bruce
Actually more like 110 CFM at 28" of water.
The LT1 flows about 50 CFM more then a stock GN.
Originally posted by blackbuick87
How does the screen come off the LT1 MAF? When I looked at mine it looks like once its off it cannot be put back on. Is it just "glued" on?
I guess I should have said "potential to flow" instead of flow.
A screenless 3.5" with a blended screen ridge can flow over 1000 CFM while a LT1 3" with the same done to it flows around 800 CFM.
A screenless 3" LT1 MAF with a blended screen ridge would flow close to, but not quite 200 CFM more than a 1 screen stocker.
I've never had a problem with a screenless LT1 (It acts 100% normal), even using chips that wouldn't run with a screenless stocker.
At what kind of pressure drop are you flowing these at?. Or do you mean when in a boost condition can flow that much?.
