M&A Heads from Champion.
silly ? are they iron or alm? are they posrted more then what they come from champion and if so do you have flow numbers to compare what they come with to what they are now?
is it a champion intake matched?
Heads are ported Aluminium, if you buy them i will supply you with flow numbers.
I am only willing to sell the intake/t-body/plenum if the M&A stage III heads sell, otherwise i am going to be using them all.
Thank You.
I have a set of brand new racing wheels and tires if you want to trade for the heads?
Brand new never mounted on car Auto Drags ,15 x 6"s with MT 27.5"sportsman fronts, 15 x 8.5"s with 28 x 9"MT et drags-actual height 27.4", comes with the proper MT tubes,mounted balanced and bead screws for the rear slicks.centercaps included.
For the record the heads did have a couple cracks which were welded and repaired by Champion.
The heads were also ceramic sealed by Champion and were pressure tested to assure the leaks were fixed.
I have not used the heads since Champion returned them too me as i have no motor to put them on at this time.
They are set up for a Hyd roller cam and have some trick oversize valves installed.
Heads are ready to install and come with everything you need/gaskets/valve covers/roller rockers and related hardware.
Thanks for looking!:wink:
