Machining heads (rocker towers) for roller rockers-- any differences by manufacturer?
GN SBS
Wanted to find out if there are any differences in the way the rocker towers need to be modified to accept roller rockers depending on the manufacturer used.
I will be using a T&D roller rocker assembly, but don't have it handy to give to the machinist along with my heads. He's done a ton of TR heads, but wanted to know if there are any specific instructions I need to provide for T&D vs Harland Sharpe, etc...
thanks!
Scott
I'll answer my own question-- the consensus is that there is no difference.
Should there be ANY contact betweek the washers next to the rocker arms and the rocker shaft pedestal?
Pedestal
I am in the process of getting a broken pedestal replaced (actually all 3 on one head ) One broke off and the other 2 were cracked. A combination of over torqueing and instead of haveing a machine shop mill away only the necessary amount----I did it with a die grinder. My suggestion would be to have your pedestal cut NO MORE than necessary to clear!!! Torque to 25 ft. lbs. with oil !!!! Here/s somthing else I found. The hole in the pedestal is drilled and tapped an extra .500 deeper than we are using with factory bolts. Which BTW are very good bolts. I purchased 2 in.( under the head length) grade 8 bolts and run a tap in the hole to be sure they were clear. Did some measuring with calipers to make sure that they don/t bottom out and will be using them on my other side.
