Jan Larsson
- Nov 22, 2001
Guys need your advice and comments ...
Machine shop is line boring and honing the main caps (new steel billet center caps), cutting the crank 20 ....
Got this from them today:
The tops of the cylinder block need machining 10 thou, as they are not parallel to the centreline of the crank.
The problem is, this would mean the pistons being out the top of the block, which would mean the piston crowns would mean machining, which would put up the compression ratio.
I got Ross forged pistons in there with OEM conrods with floating pins (OEM conrtods had small end bushed at some point), the conrods will be replaced with Eagle H beam forged rods as the pins and bushings in the OEM are shot ...
What would you guys do and recommend in this case?
