Made my own bearing chamfer tool
Mike T
Decided to chamfer my bearings a little just to make sure that there would be no contact with the fillets ....didn't feel like hunting down a machinist to do it so I made a tool.
Fairly simple...I made an adapter out of aluminum on the lathe to fit the pilot cone from my cam bearing installation tool, fitted a stainless shaft to the adapter and then wrapped the cone with adhesive sand paper.
Worked out well now I'll need to clean the block thoroughly before assembly.
This is something that needs to be done to all the main bearings when doing a rebuild?
Mine doesnt have that I don't think. It helps long term but I have over 40k on mine since being rebuilt, no issues
Useful tool when using a forged crank from China. Some of the earlier cranks with curved fillets were not machined perfectly and would catch the edge of the bearing. The tool might work on the rods too if you want to use wide rod bearings on those cranks.
I plan to run a forged rotating assembly.
Great tool, Mike. My forged crank from Weber wouldn't spin in my block. This was what they did to fix the problem.
Any other ways of doing this? I don't have a cam bearing installer
Sent from my VS990 using Tapatalk
Oreillys(or advanced) sells just the cone, or you could check out an arts 'n crafts store. They probably have some sort of wooden cone for making gawdy mini crimmus trees or something.
..or you could just by a cone tool for chamfering cylinder bores. Those will go small enough to do a bearing set.
Two additional tips if you do it the way I did.
The front main only needs to be chamfered on one side. Also the tool was too large to do the seal side of the rear main so I made a jig using two old main caps in a vise.
I needed more chamfer too. Here's a neat setup Richard Clark made and let me use. Thanks Richard!
