For what its worth here is something we discovered while at the nats.
Two nearly stock GN's (86 & 87). Both performed as expected for their mods. The only odd thing was too much knock on pump gas at only 12-13 pounds of boost, attributed to our current crappy gas. This was even with the power plate. The 86 was run at the nats with 5 gallons of 105 and still knocked. Attached Direct Scan and the only clue was the MAF numbers maxed at 200. Put on a known good MAF and the numbers maxed at 255, knock went away, even at 17 pounds of boost.
Max MAF on my 87 has always been 230. Even with the power plate I've had to dial down the boost to 12 to keep it from knocking. Put on the LT1 MAF and now boost is back to 14 with no knock.
Both cars ran well, idled well, got great mileage but both had bad MAF's.
