MAF operation, good or bad?
PaulRV6
I have an 84 engine using an 86 MAF. The engine starts and runs with the MAF unplugged. I am using a stock 87 chip. If I plug it in the engine will stumble and stall. Will the engine run with it unplugged? So what does this tell me? Thanks
If it runs better with the MAF unplugged, likely a bad MAF. ECU goes into limp mode with the MAF unplugged and runs off the CALPAC chip, if memory serves.
I believe it will still run without the calpak chip but may trigger the engine check light?
