MAF PRO/ boost sylonoid ?
DCVING 6
I am wiring in the high boost sylonoid and do not see in any of the user manuals which pin in the ECM the single purple wire is supposed to tap into. Anyone know?
Sent you a PM.
But for the archives:
For the boost wire ( purple wire, 8 pin harness ) you just splice into it at the ecm. Cut the wastegate
solenoid wire ( it's the pink wire with the white stripe it is located at
the D3 pin out at the ecm ) and the end that leads out to the motor side is
the one you connect the purple wire to. It's easier to connect it inside the
car at the ecm not running the wires out under the hood. Just locate D3 on
the ecm harness connectors. Install a male on
the purple boost harness wire and a female on the cut wire that goes out
under the hood. Also put a male connctor on the ecm side of the wire you
cut that way you can just plug the 2 cut wires into each other if for some
reason you have to take the Pro set up out. HTH
Hi Donnie
Thanks for sharing your response.
Question, if I have the boost solenoid and harness, do I still have to splice into the ECM? Or is plugging the harness into the MAFTPRO and solenoid into the vacuum lines enough to have boost control.
ajcgn said:
Hi Donnie
There is a 8 pin plug that plugs into the pro box with one purple wire that needs to tap into the ECM. Wish I had known, I could have saved on shipping when I ordered the other stuff.
BTW, you will of course need the PRO chip in order for the boost control feature to work.
Thanks guys.
Got the pro chip.
The install will be painless as I will be getting someone else to do it for me.
A lack of knowledge on my part is a money making opportunity for someone else.
