MAF question
Pace 1989
Running direct scan on my TTA, and everything looks fine except the MAF readings. It goes from 17g/s to 250 to 150 to 80 to 213, (you get the picture). It flies up and down each frame.
I'm using the extender chip and have SMC's etoh kit. I'm also using an LT1 3" sensor, and have swapped to another 3" sensor and it gives the same readings.
Any ideas?
Thanks, Ken
I had cleaned them several times when I first started using DS because I thought there was a software issue, but it turned out to be a problem with the laptop.
I still have no idea why the MAF at wot gives this info. Happens everytime.
any ideas?
Ken
