czimpel
Boost...gotta get some!
- Aug 16, 2012
Just got my car back together after a bunch of upgrades, and I'm having some issues.
New TT E85 Chip
New 120lb injectors from TT
Modded ECM
New valve springs
New Accufab AFPR
DW300 Pump-used
New Duttweiler Neck stock IC
Stock MAF
Fired it up last night without the MAF on it and it started and idled good. Never tried getting on the throttle.
• Hooked up the CAI and MAF last night and went to bed.
• Went out to fire it up this AM and it would start, run for about 5 sec, and stall.
• Tried three times with same results.
• I could use the throttle to keep it running.
• Unplugged the MAF and the problem went away.
• Tried tapping on it with it plugged in with no luck.
• Sounds like it is running super rich.
Any ideas?
			New TT E85 Chip
Modded ECM
New valve springs
New Accufab AFPR
DW300 Pump-used
Stock MAF
Any ideas?
