Maf Readings
PaulRV6
While testing last nite, I noticed that my TPS was at 2.3v while I was showing 233g/s for air flow. Isn't 255 maxed out? If so how could I be at such a high air flow at only 1/2 throttle? What am I missing. This is using TL 4.0 ver. Thanks
paul
Airflow is dependent on load, throttle position, etc.
If the motor was under load and it needed that much air, it will take that much air. (Clear as mud, right? :))
I guess what I'm struggling to say is that the MAF (unless it is faulty) will read the amount of air the motor is demanding, and it is possible for the motor to demand more air under load, regardless of throttle position.
