Extender stuff
Well,.................no.
The MaxE is a thumbwheel chip that is open loop at all times. You can adjust fuel
delivery with it by changing the 'wheel' setting. It has a lot of wiz-bang features
to let you tune it in (you have to since it can't learn) Steve Y is a good guy and his
product is excellent, although I have never used one. The "MaxE" is intended more for
track-time than street-time although many people use it on the street.
The MaxE does not read airflow beyond the 255 limit.
The Extender is a single chip. It's fancy features are manipulated by storing
trouble codes in the ECM memory. It is normally closed loop by default but
the user can change that by storing codes. The extender measures all the air
entering the engine so it can calculate the correct ammount of fuel to inject.
By adjusting the knobs in the translator you can adjust the fuel delivery up
down quite a bit. The extender is intended primarily at fast daily drivers and I have
spend a lot of time on the driveability stuff. The extender would work extremely well
with your combo.
TurboBob
![Cool :cool: :cool:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
