MAFLESS MaxEffort 16
aperrego
Drunk? I'll Check. :)
Anyone run one of these? I was told by going mafless and my setup I would need a 3bar map and NO O2 Sensor?
How would you measure the exhaust then??????
Eastern Performance sells a kit called the "Biometric Exhaust Measurement Adapter." It hooks up a special carbon fiber conduit from the existing O2 sensor port in the header to a billet aluminum coupling in the defroster vent, allowing the driver to constantly monitor the exhaust.
Well hell I better get one of those since I run the "R":D **must be something Steve hasn't told us about.
Dan
You do need a 3 bar, and the 02 still reads but the computer doesn't use the input for adjustments.
so i would get readings from scan master or similar? correct?
Oh yea, you can still read it from the scanmaster if you want. To see what's going on at that time.
