I have a MAFTPro for sale. It is still installed on my Buick which I drove today (then tore a part) so I know its working. I have had it less than a season and have done some leg work for anyone running this system. You can see my not so pretty (I suck at writing an article with pictures included) article on how to get the TunerPro RT software working and logging data with the MAFTPro. Thats found here, A newbies guide to setting up the MAFTPro on a TR You can see where I hide mine along with the different screens here, I finally got the MAF Translator Pro hooked up and working in my 1987 Grand National.
I believe I have all the documents and the box it came in still.
Here is a link to what it can do, MAF Translator
This unit sells new for $400 plus shipping from Full Throttle.
The wideband o2 is less than two months old. The car has only been run three times with the wideband installed. This unit is hardwired into the MAFTPro which takes over the AFR tracking although you can still use Logworks if you want to. I have everything for that as well including the bung, all wiring, working o2 (still in the car so I know its working). You can run this independent of the MAFTPro or directly wired into it. I have printed off the wiring diagram that spells out what wires go where to hook it up to the MAFTPro.
This is what is included,
MAFTPro (like new)
Wiring harness for MAFTPro
Innovate Wideband o2 LC-1 (sells for $200) Has everything to hook up to laptop.
Extender Pro chip for the MAFTPro (sells for $120)
I can also throw in an old laptop and include my bin files which should get you up and running. This is a complete plug and play system, the only thing you need to buy is a 3 bar MAP sensor and you will be set.
Taking reasonable offers. I really would not like to but if you need a factory ECM I will sell mine with this kit. Although I am running this on my car right now, I am not comfortable supporting this. The documentation included along with my links at the top should get you far with this.
I am selling because I couldnt pass up the deal I got on a FAST system.
PM me if you need any additional information. You can also email me at Boosted6GN@gmail.com
Thanks.
MAFTPro (like new)
Thanks.
