Making my own TV brackets/linkage setup? Geometry?
Warrant
It seems that Geometry is really important in the TV setup. What is the "geometry" refering to? Where the cable hooks onto the carb? How far it travels on the carb? The distance and angle of the wire and bracket?
All the kits seem to be really expensive. Bow tie Overdrives kit is nearly 100 bucks for just the brackets and cable.
So I was thinking about buying just the cable ofcourse and then the special little boomerang shaped TV cable corrector for a Holley Carb.
- Then I would make my own back bracket for the end of the cable housing (where you would push/clip it in the square). Does it matter how far the end of the housing/bracket is??? Does it matter that angle it is coming in at? If its parrallel or not?
- Also what about the TV plunger spring? BTO has a custom lenght spring to prevent "short spring syndrome" Would I need a different TV plunger spring?
Thanks!
Thats a great site.
I think i got it.
Ill make a backet for the end cable housing to mount in a convinent spot. It doesnt matter the location if I use a universal cable.
Ill get that carb bracket to make sure that those degree/geometry angles are correct to throttle position. Its cheap.
Properly adjust the cable
Sounds pretty easy.
I guess I dont need a special TV plunger spring in the valve body??
Anything else wrong here?
