Whole S- - T Pot of Buick Parts.
Here's a bunch of Buick parts, I'd like to unload. Lots of them off my show car I totaled.
1 - Rear center filler that license plate mounts to. Perfect shape, can bolt it on and go. $50
2 - Low mile GM coil pack and ignition module. $150
3 - Like new GN horn cap complete. $250
4 - LS1 3 &1/2in. maf sensor, polished aluminum 3 & 1/2in. pipe, 6.25 translator and adapter short harness. I have just over $450 in this and was only on my car for a few weeks. $350
5 - Console factory top shift plate. Very Nice. $150
6 - Brand new gray shift handle with a new plunger ( slide ) and spring. $75
7 - Used but excellent black ( complete ) shift handle. $75
8 - Seat belt holders. perfect. $25 for the pair
9 - Left & right seat belt retractors, that go in the door jamb. $75 for the pair.
10 - Liquid filled Marshall FP gauge with fittings. $45
11- Brand new Aeromotive liquid filled FP gauge Has the reset button on it. $40
12 - Factory radio brackets. $20
13 - Pair of chromed gas tank straps. I paid $100 just to get them chromed. Perfect shape and chrome job. $50
14 - Casper's 102033 high current fuel injector harness. Only a couple of months old and in perfect shape. Paid $128 delivered.
sell for $100.
15 - Brand new Casper's audible knock gauge. $50
16 - Cig. lighter & socket $50
17 - Kenny Bell blue fuel pressure regulator. Perfect shape. $75
18 - Highly polished A/C dryer with polished block off caps I had made. $50
19 - Firewall mount for powermaster. Redone. $35
20 - Nice license plate light. $25
21 - Very low mile stock A/C Delco maf sensor. $150 with rare chrome cover or $125 without.
22 - Brand new 255 Walbro fuel pump kit. $100
23 - Both black door jamb vents. Very nice shape. $30 for the pair.
24 - ECM out of my 47,000 mile car. worked perfect. $125
25 - 4 headlight retainer rings and in nice shape. $50
26 - Two brand new GM - GN fender badges. $50 each
27 - Perfect gray collar for underneath steering wheel. $25
28 - New GM antenna repair kit. $35
29 - Low mile A/C Delco crank sensor with mounting bracket & bolt. $50
30 - Brand new gray upper dash speaker cover. Just paid $210 for it. Sell $150
31 - Stainless steel thermostat housing with hold down clamp and new 160 degree thermostat.$35
32 - Pair of NOS H/L bezels in the GM boxes but boxes are kind of rough. $300
33 - Front license plate mount. $25
34 - Brake switch ( used for a test and removed ) as new. $50
35 - RJC power plate for Precision plenum. $45
36 - Chrome rad cap. Nice. $20
37 - Plain egr aluminum block off plate. $10
38 - Nke newos delay relay . $75 each
39 - Nos a/c delco TPS. $30
40 - Used but good wastegate solenoid. $45
41 - Kirban pinion snubber. Rubber chipped off a little on one side of the top. $15
42 - Throttle cable brackets. One powder coated blue and one like new in black. With stainless steel allen head mounting bolts. $45 each
43 - One new a/c delco ox sensor and one low miles good used one. $20 for the new one and $10 for the used one.
44 - Nos drivers side dual window switches with chrome bezel. $25
45 - Like new trunk adjustable rubbers. $10 a pair.
46 - Pair of original exhaust hangers with bolts. $45 a pair.
47 - Two new lower body bushings from Kirban's with bolts and washers. $15
48 - No pic. but sandblasted and painted with Hi - Temp gloss black paint ATR rear sway bar.
49 - No pic, but a complete set of GN front seat belts. Darn near perfect. $250
50 - Mint set of a/c and heater controls. $50
51 - Front dash, doors and rear speaker set up for concert sound. Rear's are 4 & 1/4 by 10 in. and are new Ks 410 4ohm Kicker's and the door ones are new 5 & 1/4 in. 4ohm CS5 Kickers. Fronts are stock GM and are in perfect shape. Rears have to be bolted in but door speakers mount right in. $150 with the two C/S mounting baskets.
52 - Stock shifter in perfect shape, the chrome stalk is perfect. $150
53 - MTX - L Innovate Digital Air / Fuel Ratio Gauge, complete and in it's original box with one barely used sensor and one brand new one. $200.
54 - Low mileage cam sensor with cap. $150
55 - New astro roof seal for the glass from Gbody $100
NOTE ALL Prats are Plus Shipping and a 3% PP. fee.
Thanks Mike
More pics.
Few more pics.
Ill take number 10 and 31 to 60101. Is that a stay down rear plate bracket? If so let me know how much
I'll take #20 - Nice license plate light. $25, shipped to the usual
Mike, can ya PM me a close up pic plz
I'll take:
28 - GM Antenna Repair Kit
41 - Kirban Pinion Snubber
45 - Trunk Adjuster Rubber
7 - Black Shift Handle Complete
Mike,
Does 13 (gas tank straps) include the bolts? Also can you give me a shipping quote on 8, 13, 18, 29, 37, and 42 (black)? Shipped to 45385
