mikestertwo
 - Sep 13, 2006
I hear this statement a lot but it has not been my experience. I used a tensioner/damper on a double roller chain in an engine for my '87 GN I built back in '94 "before I knew any better". I was really concerned about it after reading all the "bad" things on this site about using one with a double roller. I tore the engine down last year to do upgrades (roller cam, ported heads/manifold) with the engine having just under 50K miles on it. The tensioner looked almost like the day I put it in. It had very little wear on it. So I'm thinking there has to be another reason why people are "mangling" the tensioners. I still use them in my engines. It keeps the chain from "whipping" when they start to stretch and loosen up a bit. Maybe the type of oil being used?1st thing that jumps out is the timing chain tensioner. It's not suppose to be there. It gets deleted when using a double roller chain. Lucky it's still intact. They usually get mangled when used on a double roller chain.
Rick
