Manual TCC lockup switch wiring?
Put a switch between terminals "A" and "F" on your ALDL connector.
Sorry, I'm a wiring idiot.
Does this mean to take a 2 pole on/off toggle switch and splice the wire that goes from the "A" terminal and run it to one pole, and then splice the wire at the "F" terminal and run it to the other pole?
I think the car had a switch that has center off with up or down on and was wired for the TCC one way, and flipping the switch the other way turned on the fan.
:confused:
You are grounding Pin F so on the ALDL there is a Tan & Black wire going to pin F If you ground it the TC will lock up. Put a switch there if you like for another option.
