MAP Sensor Bolts
krazy86t
my car came with digital dash, so has a boost switch that lights up dash bulb for Turbo Power. Swapping in a 3 bar MAP for Alky. I don't have the screws or bolts to attach the MAP to the mounting bracket - what diameter and pitch are these screws? (guessing something metric, possibly M6 x 1) Thanks
images
looks like this has 7mm hex head the threads are about 1 1/8" long and about 1/8" in diameter
thanks for the replies - I clearly over-thought this. Mounting bracket isn't threaded, so any sheet metal screw that is close will work, or zip ties
