Sep 27, 2010 #1 X XBreed Member Joined Mar 3, 2008 Messages 106 Does it need to be hooked up to Vaccum and if so where is it supposed to tie in? Thanks
Sep 27, 2010 #2 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 XBreed said: Does it need to be hooked up to Vaccum and if so where is it supposed to tie in? Thanks Click to expand... It normally ties in to one of the vacuum hard lines coming off the vacuum block on top of the throttle body. It is only used to run the boost gauge.
Sep 28, 2010 #4 X XBreed Member Joined Mar 3, 2008 Messages 106 Thanks guys. Guess I don't need it like others told me I did
Sep 29, 2010 #5 jasjamz THS Racer Joined Sep 30, 2004 Messages 5,982 If the car has an alky kit you do. If it has a speed density chip or aftermarket ECU you do. And, if you use the power logger it needs it to measure boost pressure.
