87gn-newbee
- May 25, 2001
Not understanding the direction in Razors kit. Is the TPS/MAP harness need or do you just splice into green wire on stock harness at the map sensor and run that wire into the PAC in the car?
Stock harness stays unplugged if using the harness supplied with the kit correct?
Hope I made that clear....
