March Clean Out Sale
10SECONDVSIX
MORE AIR
Used GN Transmission BRF Needs Rebuilding $200
Modified D5 Converter NEVER USED 2800-3000 Stall $375
Auto Meter Fuel Sender gauge 2 5/8 "
(Good for a Race Car) $40
Billet Reducer 4" x 3" $20
Vacuum Conversion Brake Kit $50
Stock Rockers $25
Adjustable Actuactor #144 $50
Adjustable Actuactor Reg. $35
.63 Garrett Exh. Housing for "P" Trim $50
Fuel Hanger (Sender) 2 In stock $75 ea.
PT51 Turbo needs rebuild $125
EGR Black Cap $10
EGR Solenoid with Hoses $50
Stock Inter Cooler Fan $30
Stock Inter Cooler Brackets $30 ea.
Stock Breather & Pipe to Turbo $30
New Air Duct to Stco Canister # 25525539 $40
Torque Converter Shield (like new) $20
Stock Air Filter Canister $50
Stock New Pushrods $35
Stock Turbo without Exh. Housing (needs rebuilding) $50
Oil Filter Adapter with Hoses to Rad $50
Power Master Cylinder $50
Power Master Motor $50
Stock Fuel Regulator (2 in stock) $20 ea.
237 Fuel Regulator $30
Auto Meter 2 5/8" Black Mounting Cup $20
BBC Valve Spring with Retainers & Locks ( Ideal for Solid Roller Cams) $100
Strange C-Clip Eliminator for Axles 1.531" Diameter $50
Rubber Hose Reducer 3" x 2.5" $5
Plenum Spacers 1/2" (2 in stock) $20 ea.
Blow Off Valve mounted on Stock Up Pipe (don't know the brand) $60
Roller Cam Timing Chain Set $40
T Type Horn Button (like New) $15
Passenger side Table Bushing protector (Clamps on DP) S/S $15
New ESC Module $40
Cam Sensor Caps (3 in stock) $10 ea.
Stock Injectors $40
Stock Plenum $30
ARP Head Bolts 86-87 (used) $40
ATR WG Spring #14 $15
Stock Valve Covers $50
Will that '.63 Garrett Exh. Housing for "P" Trim' fit a Precision PT61?
Also, does the PT51 have a housing?
Blow off valve, please. Got any pics?
Stock Rockers $25
EGR Black Cap $10
New ESC Module $40
Stock Injectors $40
Stock Plenum $30
Flowmaster 4" #54040 $75
Pics are available. Prices do not include Shipping
.63 Garret will fit the PT61
For the Blow Off, I will need your email address so I can send you pic..
I do not have a Complete Rear. But a friend has a rolling Chassis for sale..$6000
and what about the PT51... does it have an exh housing? does it have play, is that why it needs a rebuild? any pics? my email: sra@usa.net
Pics have been sent..
Location, Montreal, Quebec, Canada
I also have a set of front Runners P165SR15 $70
Hoosier Slick 28 x 10 more than 1/2 left $250
TE64 Turbo/.63 PTE "P" Trim Good Condition $600
Stock Inter-Cooler $75
Thank you
Ill take the 3 cam sensor caps(i dont want any with cracks), Powermaster motor (as long as its good), and the billet reducer(If its for the air inlet). Have the wheels on the PT51 been damaged at all? If it just has some thrust or smokes i am interested. Let me know how you would like to be paid. Thanks
e-mail
sorry forgot to send my e-mail address. New pm sent with e-mail for pics.
Cam Sensors have NO Cracks.
PT51 is sold
.63 Garrett is sold.
Robert, pic has been sent.
I have a Casper Heated 02 Sensor with a New Bosch 02 $40
Thanks again
Joe
Joe will you take $90 for the blow off and O2s?
Is the ESC module the coil pack, the module beneath it or the ESC sensor that mounts on the PS fender. Could you email a picture to me?
davis4@theinter.com
Thanks,
Roger
If the vacuum brake conversion kit is complete and missing no parts, I'll take it. Please email or PM me. Thanks. Doug
