Im hving this problem and been cracking my head to solve it. Ive changed to Turbosmart Race Port BOV but its still the same! When part throttle my engine will judder and the boost meter will go haywire....
When WOT ive no problem at all but when i lift off the throttle a little the problem comes immediately...
What should i do? Ive tried to stiffen my BOV spring but its still the same!
Ive tried switching off my Profec B II boost controller and the problem goes away immediately but my boost is only 1.3bar as when my B/C is on my boost is 1.6bar
Do i really a more stiffer spring as ive tried putting 2 springs on my bov but the problem still persist.
Ive tried the softest & medium spring tension but i will encounter premature opening on my bov.
When i go for the dual springs combination, the premature opening solved but the engine judder still occur whenever i lift off partial throttle during WOT.
Pls advise & how to solve this plm?
My setup :
GT3076R
GSC S2 cams
85.5mm Pistons
My setup :
GT3076R
GSC S2 cams
85.5mm Pistons
