I will most likely go with a 400 trans. Car weighs 3450 with me in it. I will launch off a brake, Metco rear suspension with anti roll bar, similar to the Wolf Industries bar, Stock GN rear end gear ratio, spool with hardened axles. 28" tall tires. Motor will provide 800-850 HP. I am looking to run thru the traps at 7000 RPM. Would I use a stock 400 gear ratio? And what stall convertor would you run?
Larry
