May 12, 2005 #1 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 what is the max boost put through GN-1 heads and with what turbo?
May 12, 2005 #2 H HighPSI Moderator Staff member Joined May 24, 2001 Messages 5,978 Originally posted by 49-blues what is the max boost put through GN-1 heads and with what turbo? Click to expand... Last year I made a couple of passes at over 40psi with a PTE 88
May 12, 2005 #3 X XLR8 Lost at Altitude Joined May 30, 2001 Messages 2,197 A friend with fully ported GN-1s and a stealth turbo - a 70mm wheel in a stock housing I think - is all done at 26# at 5800' elevation it just wont build more boost.
May 13, 2005 #4 4 49-blues Active Member Joined May 30, 2001 Messages 7,628 Cal- WOW, what head gaskets did you have on the block to get that 40psi and keep everything together? I take it was on a stage block right?
May 13, 2005 #5 H HighPSI Moderator Staff member Joined May 24, 2001 Messages 5,978 1007 gaskets. I don't normally run that much boost. I just was just trying to go faster
