bird
- Feb 20, 2003
anyone run the same boost on alky, as with race fuel(c-16)? i usually run my boost in the mid to upper 20's with c-16. trying to decide if i could run the same #'s with alky?
SignUp Now!pacecarta said:i dont agree
without an intercooler upgrade c-16 is not a substitute for alkyand will not out do the boost you can run on alky due to the cooling effect on the intake charge as well as the cylinder cooling the alky provides and still run an O2 sensor without fear of killing it
and as for timing , i run 27.6 /24 on alky at 28 psi with a stock duttneck i/c and on some of the hottest days of the year when its been 90+ degrees and over 100 track temp
but get a cool day and if you have a big frontmount intercooler the c16 will tolerate more timing and you should be ableto run boost near or over 30lbs
Russ Merritt said:That is true, doing it with a scanmaster is tough. Doing it with anything, even directscan with the narrow band 02 sensor will never be that accurate on air/fuel ratio. That is why I went to the dyno and used a wideband.
Directscan is a great tool and I love it. Knock counts/retard, timing, MAT temps, coolant temp, Load value, rpm, and being able to record it all is awesome BUT, I refuse to believe one cannot tune an alky/pump gas vehicle with a scanmaster/dyno/wideband. I know it can be done......
Russ Merritt said:Dude, your car's all F***** up.......
Mine isn't......... I'll leave it at that.
Razor said:Russ.. you and me are on the same playing field. Point is when you were on the dyno with the wideband.. and started having issues.. you were stuck with what was allowed on the chip for changes. The Direct Scan lets guys like me and Steve see whats going on and play back runs to see if something sticks out.
Hence why I said engine management. The ability to make changes on the fly. Hell I would tell you to play with a spark translator and a lower timing ME-r. That way you start low and work your way up on timing via the spark translator. At WOT you have spark and fuel. And I've tuned plenty of these cars with the junk single wire O2's with great success
Tell Steve to make you a dual timing chip. Pos 1-8 like 18 degree's, pos 9-F like 22 degree's. And set the fueling center like pos 6 you were running. Target 760-770 at WOT 100-110 MPH with the twins.. see where that takes you.
